Husqvarna 3120
ajschainsaws
Axes never run out of Gas
11:22 AM
South west UK
I gotta husqvarna 3120 early model without choke just purge button
I've put a new cylinder piston pressure tested and put a new coil on it and put a full carb kit on it and it is now doing some funny things in a pattern every time
It starts in two pulls give it a bit of throttle it burbles runs like a bag of s~~~~ then it backfires
Go to start it again and it starts and runs fantastic no tuning needed it wasn't until I looked at the chain when it's slowing down too stop I noticed the chain is running BACKWARDS
All new parts OEM
clutch has been threadlocked , as a perfect hole was cut a few weeks ago by the clutch in the cover with the bar and chain which pushed me too get down and dirty with this SOB
And i left it a few weeks and got back too it yesterday
When I restart it it does the same runs like a bag of nails then backfires and so on
Now would the flywheel have de magnetised
Any help will be appreciated
Deets066
AKA Deetsey
6:22 AM
So, you had your chain on backwards? or the engine rotation was backwards?
ajschainsaws
11:22 AM
South west UK
I don't think so as 1st time starting it runs forward then backfires and next time you get it stared its running backwards
6:22 AM
I've had that happen with the 385 when the coil came loose
ajschainsaws
11:22 AM
South west UK
When I was having a go at this saw a few weeks ago there was a cheap copy coil fitted on the saw that was a loose fit there was so much play on the mounts there where no numbers on this coil to identify it I put a OEM coil on it now
But what I noticed a few weeks ago that slipped my memory was this cheap coil was running on a different line on the flywheel than the original one
Now I have put this new coil on it's running along the original path
