brox
I have a Husqvarna 285CD I am trying to resurrect for a family friend. He has a sentimental attachment to the saw and would love to see it run again. It does not have spark and so far haven’t been able to get there. I bought a NOS ignition from Chris at Saw Salvage thinking that would fix it. Still didn’t have spark with or with the kill switch in the circuit. The insulation on the kill switch wire from the ignition had small cracks in it given the age of these units. I covered the whole wire in heat shrink to seal it up. Only problem is the wire comes through a hole in the ignition and makes a u-turn into the body. I ran heat shrink through the body but wasn’t able to make the u-turn so I coated the wire in several coats of liquid electrical tape. I am confident the kill switch wire is sealed up and not grounding out against the body.
I still don’t have spark when turning the motor over with a drill. There is nothing visual wrong with the flywheel and I have never had one go bad before but I don’t have that much electrical troubleshooting experience. I am debating buying a flywheel to try if I can find one but also wondering how much money to sink in to the CD ignition system. I have read about upgrading to SEM and wishing I had gone that way at this point but have already sank a lot into the CD ignition. Is there anything different about these CD ignitions that I need to check? Any ideas?
Thanks,
Brock
Thanks,
Brock
