Husqvarna 2100 CD ignition trouble
SOHC
2:52 AM
Newzealand
Hello i have a couple of husqvarna 2100cd saws, one has no spark, it has a totally different looking flywheel and ignition system, it looks like the one on the RH side with smaller fins and red HT lead and module,
Can I fit a replacement module from amazon or ebay? They look different
SOHC
2:52 AM
Newzealand
How are the pullstart pawls held on to the FEMSA flywheel? Cerclips? They have been tied on with nylon on this saw, I gess the clips dont like the rpm?20231103_123247.jpg
Here for the Yum Yum Sauce
8:52 AM
Unless you can make some kind of artwork out of it, there's not much you can do with the femsa parts, unfortunately.
A new SEM cd ignition is available from Husqvarna, as previously stated, it needs to be used with a SEM flywheel to function properly.
9:52 AM
Somebody on one of the forums found an AM source for the SEM coil but I forgot who or where .At one time if you could even find a new OEM they were fetching in the $200 range .The used coil I got from Bryce set be back $50 .The saw is a screamer but lately I can't even roll it over .Needs a little attention evidently or a kick starter .
Squareground3691
9:52 AM
New England
SOHC
2:52 AM
Newzealand
I got it to spark, was the ignition switch even tho I tested it like 10 times, end snapped off and then it started sparking, I didn't have a switch but had a 180s kill button.
