husq 266 noisy clutch
jake wells
no longer here
7:58 AM
ky
replaced the needle bearing along with the drum and rim and greased the bearing lightly
clutch spring seems tight.
makes a annoying TING TING RING noise idling not sure what the hell is the racket.
trooney
Admitted Woodaholic
8:58 AM
The land of pleasant living
I had a 261 that did that too. Clutch spring seemed tight, but the shoe had a little side to side wobble, carrier was a little worn, probably enough to let the shoe touch the drum while at idle. Got another clutch and it was better. Check your carrier for wear, might be the problem. It doesn't take much.
cus_deluxe
terms of service violator
8:58 AM
Michigan
Id replace the spring anyway. A few bucks well spent, and if it doesnt fix it then you still have a fresh one if u decide to replace the clutch.
Basher
9:58 AM
Canada
I have seen many high hour saws that do that, something is tapping/touching the clutch drum to make that sound. Check the items mentioned above, especially the carrier but a new clutch would likely cure the problem.
  • Like
Reactions: DSS
T.Roller
8:58 AM
Southeast, TN
I've heard a few saws do this that there was nothing wrong with. Try idling it down just a bit.
  • Like
Reactions: DSS
trooney
Admitted Woodaholic
8:58 AM
No, mine ran fine when you throttled it up. It just sounded like something was wrong with the saw when it really wasn't, thats all.
e.fisher26
8:58 AM
Ma, USA
That is a specific sound, the drum acts like a bell when hit, so at least you know exactly where the sound is coming from. Needle bearing or drum has too much play in it I'd think
Just a home owner that likes the older better made machines
Craftsman 3.7 x2
Husqvarna 36
jake wells
no longer here
7:58 AM
ky
going to check that clutch out thanks guys.
