- 11:34 AM
- Dec 29, 2015
- Strong Island NY
Do you modify the meteor at all Doc?Lolol...
Here’s a real revelation I hadn’t figured out before.
Meteor supplies F-Cast rings with their single ringed Husqvarna pistons. I finally figured it out last night. Makes sense, as it’s only one sealing ring and a bit more tension would be beneficial. I’ve been installing F-Cast all along with these meteors.
Another pearl, the Meteor 262 piston is actually 1 gram lighter than OEM KS/Mahle slugs. By the look and feel I wouldn’t have guessed that. But the scale doesn’t lie.
View attachment 132868 View attachment 132869 View attachment 132870 View attachment 132871 View attachment 132872
Lolol...
Doc, how do you find the Meteor pistons for finish on the edges? I bought one recently for a J'Red build and thought some of the edges needed relieving to prevent oil wiping in the cylinder. Just curious if they are all that way, or if I got one that wasn't quite finished properly.
Finish is generally excellent. I used to remove any flash on the piston, but I rarely do for a Worksaw anymore. It’s needless work.
Meteor pistons are usually really good on their fit and finish
Yeah I've used a pile of them. Sometimes I'll clean them up, sometimes not. I just like to see what other guys are doing.Finish is generally excellent. I used to remove any flash on the piston, but I rarely do for a Worksaw anymore. It’s needless work.
I thought so. I usually throw OEM in all my saws. When I bought this Meteor and compared it side-by-side with an OEM, the edges are noticeably sharper on it. I'll probably just hit them with a little emery or brillo on the edges only, just to be on the safe side.
