Husky 55 intake repair
David Young
Safety First !!!!!!
10:59 AM
vt
This may be child's play for a lot of you. I work with the h 50/51/55 often because there are so many around here well known Achilles heel is the plastic intake bulk head. I think the worst part is the carb is held on by screws that secure in plastics.
Here are some pics of what I do. And a couple 1 minute vids. Hope someone find this useful.
Below first pic is the stuff I use
Second pic you can see the threads are starting to pull out
David Young
Safety First !!!!!!
10:59 AM
vt
First vid.
Pics below drilled out holes.
Tap drill is a #5. .205"
Pic 2-3
Tapping
lwhaples
10:59 AM
Vt
Nice write up and vid's. I have a 55 that I need to get put back together.
David Young
Safety First !!!!!!
10:59 AM
vt
I usually install a 5mm helicoil and then use 5mm x either 55 or 60mm allen head screws. It works for me
Thanks guys, I like this type of repair I am sure you all have them for various models. Hope it helps someone.
Yep thats what I use. M5, I thought they were 45mm but I will check the length for reference when I get home. I bought them at Fastenal because they were super cheap.
I need to get another pack of Heli coils.
If you do the repair Randy talked about put a dab of loctite on the nuts I had a buddy crunch a new meteor piston when the nut went down the intake.
@Mastermind
Randy when do you want stuff in the technical area and when in the chainsaw area?
Motorhead
Cantre Member
10:59 AM
Tampa Fla.
Some poulans have similar intake manifolds 4620 comes to mind,The poulans already have metal threads.
67L36Driver
9:59 AM
I'll have to look in my stash but, I picked up a package of machine thread inserts intended for soft material (plastic or wood) at a machine design show.
