Dirtmagnet
- 12:48 AM
- Jan 10, 2017
- Detroit
Hi everyone. Here is the 545 i picked up from eBay. It's a 2012 model that ran, but had a stuck (carboned up) ring. Since the ring was stuck, I decided to tear off the cylinder and make it right. This is going to be my first Autotune saw and used for general firewood duty. On to the pics.
Since the ring was stuck, there was quite a bit of blow-by. Here are the pictures of the piston after I cleaned it up using (carefully) green Scotch brite to remove excess carbon build up.
Here is the exhaust side of piston - a bit of wear but nothing excessive that can be felt with a fingernail.
Top of the piston (obviously OEM thankfully)
Here is the cylinder cleaned up with a Scotch brite. Looks good! Yay! All thats left is to clean the exhaust port and finish cleaning.
