J & L Creations
Machine Design
hello guys, I am in the process of rebuilding a husky 51, found a low and upper end rebuild kit. I have the old head and was wondering what could be done with it. Can it be machined an reused with a larger piston or is it worth it?
Also I have a husky 61 the muffler blew off of as the saw was in use. It blew off at such a force that the muffler bolt threads in the head pulled out. My guess is that the two piece ignition stopped sparking the spark plug, fuel built up in the hot muffler and ignited, which caused the muffler to explode internally and shear the threads and the reason I am now replacing the two piece ignition. I'm not sure this is what happened but would explain the threads in the head from being sheared and the extra hole in the muffler. So now to the question, what would you recommend as a repair, larger muffler bolts, or heli-coils and the same bolts. Either way I will have to rethread the head to a larger size. I thought about welding them up then rethreading to the standard size, but am fearful that welding it would warp the head.
I might also have to split the case to replace the gaskets and seals.
