- 8:12 AM
- Jan 12, 2016
- Iowa City
Side of the cylinder. I forgot to order it twice
Pretty sure I have an extra of those.
I have a 395 carb too, which doesn't work with the 394. Anyone have a 394 carb they want to sell?
Thought about something like that, but if I could find a cheap one I'd go that route firstDeets,
Just drill a hole into the port passage on the intake block, epoxy in a fitting, and run a pulse line.
Joe
That case 1/2 looks awful familiarMe either View attachment 24753
They aren't bad to put together.I got started on mine last night. Took as long to clean it as it did to part the cases and install a new half from ny15. I need a piston. Mine looked like the rod went through the skirt on the intake side
I picked up some used plastic today....you guys would be proud of me. Before I get any pics, I need to drag it down the road a couple miles to rub the black outta the cracksThey use the same everything..... almost
