Bada_Bing13
- 6:32 AM
- Jan 27, 2024
- Niagara Falls, NY
I have a clone kit saw, Husky 372XP with a Big Bore Kit in it, Walboro Carb, 28" Forester Bar, Genuine Husqvarna Fuel & Oil lines that was sent out to be Professionally Built, Ported and Tuned.
I'm noticing that there's A LOT of excessive bar oil that leaks out after I shut the saw off. I'm used to a little bit of oil pooling underneath it but this seems to be way too much.
Now I've already tried to fix it by using silicon to seal the lines & the rubber grommets to the pump and case. This has cut down a bit on the amount of oil but it hasn't stopped completely.
I'm wondering if there's a fix for this?? Maybe would a genuine Husqvarna Oil Pump + Oil Gear, new grommets & lines help to fix this ?
I'm open to all suggestions, Any & All help is appreciated very much
( YES the bar is receiving plenty of oiling )
Bless you and may the saw gods be ever in your favor!! Thanks Again
