Husky 357 rebuild
lehman live edge slab
Live Action
2:38 PM
Mn
Swapping cranks on a 357xp found the disassembly instructions in manual and it said to heat cases and tap crank lightly out of the cases. I followed the instructions and the bearing came with the crank is it supposed to? Already bought the crank tool to reinstall
backhoelover
I like tools
3:38 PM
lincolnton nc
Might can heat bearing up and tap it off. Also I use a hf heating gun to heat up case half and put bearing in freezer makes for easy install
Live Action
2:38 PM
Mn
So pull bearing of crank and then install in case and pull crank in then? I have a bearing puller to take the bearings off. This is the good crank that I’m replacing a low hour saw that snapped on clutch threads. I don’t have the good saw apart but if the bearings come out with the crank on that one I wonder if I should just talk him into new bearings or reuse the old ones.
cuinrearview
Handy dood
3:38 PM
Dowling, MI
If it's apart, there's really no reason not to throw new bearings in it. Especially on that saw, which uses 6202s on both sides.
