Husky 350 bar studs coming loose
RP81
10:01 PM
Adrian MO
FC5D812F-45A3-4AA1-A5D4-1B1EE83759D6.jpeg Anyone else had this problem? This is the second time it had happened.
KYsawman
11:01 PM
Gone Fishing
Yes I have fixed several, I just cleaned the tank really good and add a little motoseal to the studs and pull them back through, I make sure the little metal plate is not bent also. It usually is caused by getting the saw hung and pulling on it, I have also seen the chain break get left on and deform all the plastic around the bar plate area.
Wood Doctor
Edwin
10:01 PM
Omaha, Nebraska
This is the biggest criticism of the Husqvarna 350. It was fixed when the 353 was released. This muf mod fixes it:
Husky 350 Muf Mod.JPG The 353 has a second arm on the right going down that bolts to the case. That's not needed on the 350 if you shape the mod as shown.
Kenskip1
10:01 PM
Waynesville, Missouri
I had a similar problem with my 025.I cleaned the hole with brake clean and compressed air then mixed up a batch of J.B. weld.50/50. Anyway packed the hole with the brew then screwed the stud in.I let is set overnight and it is Stihl holding. This was over three months ago and close to a dozen tanks of mix.
Wood Doctor
Edwin
10:01 PM
Omaha, Nebraska
Therefore, that mixture you packed in was 50% JB Weld and 50% brake fluid? Seems rather amazing that it handled the heat. Oops, sorry, I thought you were talking about muffler bots.
What you concocted with JB Weld and brake fluid might have worked similar to thread-lock adhesive. Interesting...
Wood Doctor
Edwin
10:01 PM
Omaha, Nebraska
The Stihl lugs screw into the case but the Husky 350 lugs have a square head and are held in from the back side. So, two different engineering designs.
67L36Driver
10:01 PM
Them require a stack of flat washers and a nut iffin one wants to tinker much. [emoji2955]
A bench top of bar oil can happen.
[emoji2959]
Kenskip1
10:01 PM
The J. B. Weld has two tubes.Mix 50% white tube and 50% black tube. Equal portions for the slower members of the group.
I used Brake Clean to clean out the hole, then used compressed air from my 60 gallon air compressor to blow dry the arpitature.. Do not worry. I drained the moisture out of the compressor last spring.
