How would you try and save this coil
mirage
1:08 PM
idaho
Ok if I got this right. Put the head back on . Fill the cylinder with oil. Then put oil in grease gun install custom fitting in head. Remove jug nuts then pump oil into cylinder
lehman live edge slab
Live Action
2:08 PM
Mn
I’ve used hair dryers on cracked coils to dry them out then sealed in red rtv. Worked on the couple I tried on old boat motors
3:08 PM
Did I miss something .head ? I thought it was a stuck piston on a chainsaw .Most if not all them made in the last 60 years have blind end cylinders ,no removable head .
In the example I gave on the big Partner was I wasn't certain if the bearings were stuck ,which they were .So as such I just popped the cylinder off the piston rather than try and move the complete crank shaft piston assembly .
3:08 PM
Head down to the gun store and get some black powder..... Aw never mind:eusa_doh::yikes:
I actually knew this yahoo who actually did that on an old Dodge flat head with 4F muzzle loader pan powder .Took him about 3 times but he shook it loose .
semicabin
5:08 AM
Melbourne
Mirage, the place that sells them is called Saturn surplus. Google them, in there 1.5kw tab you will see a list of parts. Part number is 9786E128. They are there for $14.50.
Can you get me two if I send you PayPal? If too hard then no dramas.
Click link below
http://www.saturnsurplus.com/genset/2a016-1.htm
mirage
1:08 PM
idaho
yes it is a chainsaw. It is a Titan and they have removable heads. 0E6C07E0-A651-4E59-8126-E1FC1E51879A.jpeg
mirage
1:08 PM
idaho
Click link below
ok let me check into this. I got another saw that I think takes the same coil. I will be more than happy to sent some to you.
mirage
1:08 PM
idaho
Click link below
Talked to them yesterday and they were out of the coils. Got e-mail today they got a 1000 of them in. I order 2 for you and 2 for me. He said they sell alot of them.
semicabin
5:08 AM
Melbourne
Awesome! Great news. Yes every chainsaw collector grabs them that’s how I knew about them. There’s one who even resells them at a 300% markup.....
You may want to grab a few spares as it looks like you are hooked on vintage saws. I need two, one for my titan 200 and titan 65. I’m guessing the coil will fit a little 200, will definitely fit a 65.
Now about the stuck piston, you better heat it up a lot, wait for it to start cooling down and smack the top of the piston with a block of wood and mallet. Use penetrating oil aswell. I set the bores on fire. Did this with both my titans and now have freed pistons with decent compression. I don’t know how to explain that you need to whack the piston and take into consideration the jug mounts and anything fragile. Once it starts moving which it will it’s a great feeling. But it’s risky! The bores aren’t chromed plated so that’s in our favor.
New rings would be good after a freed piston and jug.
mirage
1:08 PM
idaho
Might get a piece of wood or plastic and put it on top of piston and hit it with a air hammer. I got a adjustable one ,I got a Disston2 man saw that the pistons were stuck on and got them freed up today.
3:08 PM
An oil soaked rag on fire it the bore is another one of many old tricks . I once freed an Allis Chalmers model WC that was stuck and some dummy pulled it at about 20 MPH ,popped the clutch and bent the rod like a pretzel .Torched the rod and jacked piston,cylinder liner and all out the top .Then used a rosebud to heat the liner . Saved every thing but the rod .
mirage
1:08 PM
idaho
Coils are in . Send me or address. You 2 were 32.50 after shipping. Don't know about shipping to you. I got the piston out. Got the jug off and put it in a press. Just before the piston was ready to come out the rod caught on the side of one of the blocks I was using. +&@^$%)*^$$&*^%$&)U MF .Yes I broke the *&!@#%I*$#$ rod. Anyone got one please let me know. I will get the coil out ASAP .Reeve
semicabin
5:08 AM
Melbourne
Righto, way to go mate, shame about the rod!
Jeff Hendricks more than likely still has a spare 60 parts saw available, he had one for $40 a few weeks back, not sure if it moved..? The stroke is the same with some of the titans I’ve noticed but not sure if conrods were same demensions/thickness/size. From what I can gather most parts are interchangeable from saw model to saw model.
Anyway will shoot through my address,
semicabin
5:08 AM
Melbourne
I see they just increased the price of the coils o_O ,
