How to repair a stripped sparkplug repair?
decableguy2000
6:29 AM
WNC
Have a 359 on my bench that looks like a "Save-A-Thread" installed once before. Went to change the plug and insert came out with the plug.
Homemade
6:29 AM
Wisconsin
Put a new helicoil in it. Or timesert brand is the best for a solid insert.
Maintenance Chief
6:29 AM
South Carolina
Time serts are awesome. However I can by a new cylinder for the cost of the sparkplug kit.
Having it welded is my go to , inserts and heli coils might? Work but welding is going to work period.
If you can get a cheap cylinder though ( sub 75.00) then thats a fix also.
Shane¹
6:29 AM
Kentucky
Getting it welded or a replacement cylinder are the best options but should be the same thread as a Triton motor maybe an automotive shop near by has a good repair kit. The inserts that come with the good repair kits are much better than the cheap $25 kits you get at AutoZone and usually the Ford repair is expensive due to labor shouldn't take long to do chainsaw cylinder.
Ronie
6:29 AM
NC
I had one that came out and whoever did the repair didn't flare the end, I put some locktite on it and used the tool had to flare it.
Maintenance Chief
6:29 AM
South Carolina
You can also rent the insert tool from O'Reilly, I did a friend's v10 once.
srcarr52
6:29 AM
Iowa City
If the insert backed out on the plug you can install a new one. Loctite and stake it well.
