How to remove a broken bolt flush with the crankcase
Paul Fithian
12:36 PM
Long Beach, IN
Here's how to remove a broken cylinder bolt that is flush or below the surface of the crankcase
Get a washer about the same ID as the bolt and weld it to the top of the broken bolt. Remove the ignition coil before welding
Add a second larger washer on top of that and weld it to the first washer/bolt
Quench with a water spray, then grab onto the second washer and unscrew the bolt
This bolt was blue Loctitied for 48 hours and came right out.
Paul Fithian
12:36 PM
Long Beach, IN
Ive always welded a nut to the broken piece. Then you have a good way to grip it😺
Agreed, one of the things we learn working on older Ford 4.6/5.4 V8's with broken exhaust manifold bolts.
For this one, almost none of the bolt was above the surface, the washer trick let's you get closer to the bolt to weld on it. With the second washer on top, it is easy to grip with a pair of pliers and rotate.
Sawpaw
Active OPE Member
12:36 PM
ArkLaTex
Excellent post, much appreciated.
davidwyby
Rural desert logging
10:36 AM
Extreme Southeast CA
Cool a little...then soak with Kroil, let the heat draw it in. Then cool the fastener completely before removing. Helps if the case is still hot. Repeat as many times as necessary. Washer, then nut. Use a small impact driver very lightly for a minute or two to work it back and forth until it comes out.
