How to measure maximum RPM on 2 stroke?
FergusonTO35
4:32 PM
Boonesborough, KY
So, is there an official way to measure maximum WOT RPM on a two stroke engine? I have always found that the longer you hold it on WOT the more RPM increases, presumably due to the mixture in the crankcase leaning out. For example, when I snap the throttle on my Echo CS-501P the RPM jumps to 12.5. But, as I hold it that climbs into the 13,000's.
Nutball
3:32 PM
Mt. Juliet, TN
I wonder if it's an echo thing, because my 2511t did that. It could be leaning out as excess fuel in the crank case dries up, but it could just be a cold cylinder getting hotter and burning fuel faster.
I measure rpm by listening to a saw tooth wave sound generator at the same time. That should get by any problems with an electric tach that could get a messy reading from a rev limiter.
r7000
4:32 PM
CT
it would be a simple matter of getting an [inductive] type rpm measurement device or tachometer, that wraps on the spark plug lead... see "rpm tester" on amazon. The more $$$ you spend, the better the functionality; my cheapo one the LCD display updates like once a second at best so to really capture maximum rpm is not really great but I can at least tell the relative range whether it's 7000, 9000, 11000, etc. and at least have some relatively accurate idea which is good enough for me for what I was willing to spend.
And there's also noncontact optical tachs that would measure the actual rotation or something.
As for "offical way"... a tachometer and the more expensive the better it's likely going to be, just make sure it supports the ignition oe # of cylinders and 2-stroke vs 4-stroke, or be prepared to either multiply or divide by 2.
EFSM
3:32 PM
Extreme southern IL
Any saw will do this until fully warmed up. Echo's tend to do it more than some due to their spark timing and lack of strato-scavenging. The 501's don't have a limiter.
dangerousatom
4:32 PM
Quakertown, PA, United States
The RPM in the cut are what you need to tune the carb for. I shoot for +11.5k on my personal saws. 10k on anything I do for a friend or random person asking for a port job unless I know they know to not stand there and throttle-jockey the saw off load. I do see my saws hit the 13.5k range when not under load, but I dont whined them out for no reason.
