How to make a band cutting mandrel
Brewz
8:12 PM
Hunter Valley - Australia
Deets, the best I can match your 90* mill bit with is a hack saw, angle grinder and a file.
Al, nice taste in beer!
Thanks for the info so far folks... keep it going cause it looks like there are a lot of members interested in learning this stuff!
Tor R
Novice, Leg model #2
10:12 AM
Mandal
Picture one. The cutter is tilted back 3*. Higher in the front (where it cuts)
thanks Al for taking your time to explain it so nice.
Used to work on a place where they have all the equipment for making mandrels for me, they sure gone work a bit lol
242,254,262 is my main saws to do some serious work with :)
Deets066
AKA Deetsey
5:12 AM
Just use the grinder, grind you a slot across the top of the mandrel. Leave it a little under sized and install HSS with a BFH
jmssaws
Banneded
4:12 AM
I cut a groove with a cut off wheel and drive a cutter in with a bfh like deets said.
No set screw.
A set screw would make it easier to angle your cutter if you want to.
5:12 AM
Sorry, bad wording on my part. Let me rephrase that; I'm wondering how you guys cut the base if you don't have a lathe?
I think @czar800 used a surface sander very carefully and then block sanded the base to its final dimension.
I wouldn't feel comfortable with anything but a lathe or a precision milling machine. If you're off at even the slightest angle with your base, especially side to side (and not perfectly 90* to the bore), I'm sure the saw will run for a good amount of time. But, it's gonna place unnatural loads on the piston and I suspect eventual failure.
My OCD-ness just won't allow it.
ABarrick
TacomaTRD98 on AS
5:12 AM
Newville, PA
I have set screws on mine. I can shim them with a piece of paper or sandpaper for angle if I want some.
Don't know if it would be worth the effort or not but how about a set screw positioned vertically underneath the cutter in the tool slot? You could set it at or below surface for a 90 degree cut or back it out incrementally and then lock the cutter with the other set screw to the angle desired.
GoBigBlue1984
Bluegrass Fart Knocker...
5:12 AM
Kentucky
These are neat and all and I've actually considered making one and seeing how well they do. I'd like to see some pictures of a band cut with the mandrel. For me though, the ten minutes it takes to set it up in the lathe and cut it I can't bring myself to try anything else.
