- 6:48 PM
- Jan 8, 2016
- Mandal
thanks Al.
3° cutting angle from the center and out? Or 3° seen from the side as in picture1?
thanks Al.
Picture one. The cutter is tilted back 3*. Higher in the front (where it cuts)thanks Al.
Can do it either way.How then do you guys cut the base? Isn't that sort of part 2 of cutting a squish?
thanks Al for taking your time to explain it so nice.Picture one. The cutter is tilted back 3*. Higher in the front (where it cuts)
Just use the grinder, grind you a slot across the top of the mandrel. Leave it a little under sized and install HSS with a BFHDeets, the best I can match your 90* mill bit with is a hack saw, angle grinder and a file.
Al, nice taste in beer!
Thanks for the info so far folks... keep it going cause it looks like there are a lot of members interested in learning this stuff!
I drilled a set screw. How do you change your cutter Deets?Just use the grinder, grind you a slot across the top of the mandrel. Leave it a little under sized and install HSS with a BFH
With mandrel cutting, I find it much more exact to measure squish, then cut the base, then cut the band.
I have set screws on mine. I can shim them with a piece of paper or sandpaper for angle if I want some.I drilled a set screw. How do you change your cutter Deets?
I get about 10 bands out of a cutter
I've done the same with slivers of brass shim materialI have set screws on mine. I can shim them with a piece of paper or sandpaper for angle if I want some.
I think @czar800 used a surface sander very carefully and then block sanded the base to its final dimension.Sorry, bad wording on my part. Let me rephrase that; I'm wondering how you guys cut the base if you don't have a lathe?
Don't know if it would be worth the effort or not but how about a set screw positioned vertically underneath the cutter in the tool slot? You could set it at or below surface for a 90 degree cut or back it out incrementally and then lock the cutter with the other set screw to the angle desired.I have set screws on mine. I can shim them with a piece of paper or sandpaper for angle if I want some.
