How do you change the front AV mounts on a 076
CoreyB
9:31 PM
South east iowa
Hey just got an stihl 076 AV to clean up and it needs the front AV mounts. This is the first time I got to even see an 076 AV in person
Would you be kind enough to share any tips trucks or photos.
I have yet to even look at it so it is probably easy so I will look real smart.
cease232
10:31 PM
Montana
I have two of these saws and the clutch side mount is impossible to find. Seems to be a weak spot as both of mine are broken. The flywheel side seems to be abundantly available. I haven't been able to jerry rig anything yet.
CoreyB
9:31 PM
South east iowa
I thought the clutch side and flywheel side where the same!
cease232
10:31 PM
Montana
I'm talking about #37 Everything else seems to be replaceable. Easy to remove, two screws on each side connected to the wrap handle.
cease232
10:31 PM
Montana
Remove the 4 screws in these holes. There's then one screw that holds the two mounts together.
