How bad are missing cooling fins?
LAWN BOY
Pothole
12:31 AM
Merrill, WI
Homelite 150 chainsaw, how bad is it that 2 cooling fins are broken off the flywheel like this?
heimannm
2:31 AM
Dike, Iowa
The balance of a single cylinder two stroke engine is not very good to begin with. In all likelihood you will not feel the difference with the saw running, and unless you run it tank after tank on the hottest days of the year cooling should not be an issue provided you keep the saw relatively clean.
Mark
LAWN BOY
Pothole
12:31 AM
Merrill, WI
I will keep the saw relatively clean and will not be using it very hard core by any means.
jacob j.
Only the weird
12:31 AM
Coastal Oregon
These little Homelites don't turn fast enough for there to be a major imbalance issue caused by the two missing fins on the flywheel.
When I was at the one dealership in the early 2000's, I would periodically service a company-owned Stihl 064 landing saw.
That saw ran with three adjoining missing cooling fins on the flywheel for twelve years in a landing environment, which is one of worst environments for a chainsaw.
What ultimately killed that saw was guys running it without an air filter of any kind.
Ronaldo
2:31 AM
Eastern Iowa
Very interesting. I certainly expected there would be more of an out of balance issue. 👍
jacob j.
Only the weird
12:31 AM
Coastal Oregon
It's intuitive to think that there would be more of an effect. These little saws are so crudely built though, like Mark said, there's not much balance there. The flywheel fins on an 064 are also pretty small and don't represent much mass.
It also has to do with how the bottom end is constructed. I believe these little Homelites use needle-roller main bearings, similar to the Stihl 020T/MS-200T, which are more forgiving of certain loads. Of course, they don't do as well at higher speeds like a caged roller ball bearing.
pbillyi69
12:31 AM
USA
i ran a work saw that was missing some fins and couldnt notice at all that they were missing. that saw was used every day by someone. it was an 026 and it lasted for the three years that i worked for that guy
Woodwackr
1:31 AM
ID
So, I shouldn’t worry too much about this one 064 FW with a couple of missing fins…got it 😁. It will go on eBay…last 🤣
