LAWN BOY
Pothole
- 11:10 AM
- Feb 27, 2024
- Merrill, WI
It would probably still move air over cylinder but I would be concerned with it vibrating from being out of balance.Homelite 150 chainsaw, how bad is it that 2 cooling fins are broken off the flywheel like this?
Amen. If you're concerned, you could tap a hole in that area and add a bolt with a stack of washers for a weight.The balance of a single cylinder two stroke engine is not very good to begin with.
Well he will get an education that wayRun it and find out.
Very interesting. I certainly expected there would be more of an out of balance issue.These little Homelites don't turn fast enough for there to be a major imbalance issue caused by the two missing fins on the flywheel.
When I was at the one dealership in the early 2000's, I would periodically service a company-owned Stihl 064 landing saw.
That saw ran with three adjoining missing cooling fins on the flywheel for twelve years in a landing environment, which is one of worst environments for a chainsaw.
What ultimately killed that saw was guys running it without an air filter of any kind.
Very interesting. I certainly expected there would be more of an out of balance issue.![]()
So, I shouldn’t worry too much about this one 064 FW with a couple of missing fins…got itIt's intuitive to think that there would be more of an effect. These little saws are so crudely built though, like Mark said, there's not much balance there. The flywheel fins on an 064 are also pretty small and don't represent much mass.
It also has to do with how the bottom end is constructed. I believe these little Homelites use needle-roller main bearings, similar to the Stihl 020T/MS-200T, which are more forgiving of certain loads. Of course, they don't do as well at higher speeds like a caged roller ball bearing.
