How are the Asian 660s holding up???
K robbers
Active OPE Member
5:16 PM
upload_2019-3-12_18-55-43.jpeg upload_2019-3-12_18-58-14.jpeg upload_2019-3-12_19-8-9.jpeg I like your post I’ve been working on similar problems I have the Huzti 660 also blue I had no oil from out of the box found out the case was not machined enuf around the oil pump drive and the oil pump drive wire cut a new path on it’s own upload_2019-3-12_18-55-43.jpegthe pump was destroyed I replaced it and the pickup line and the oil pump drive after re cutting the case to clear upload_2019-3-12_18-58-14.jpegnow I have oil but it’s not enuf half tank of oil to one tank gas and the oil vale - cam all the way open or full oil so I’m wondering if my oil to thick it’s cold 32 degrees hear and the chain oil is malaises I’m going to try thinner oil and see any ideas ? upload_2019-3-12_19-8-9.jpegBut the saw is running grate
danimal
7:16 PM
Armpit of da Midwest
View attachment 170577 View attachment 170578 View attachment 170579 I like your post I’ve been working on similar problems I have the Huzti 660 also blue I had no oil from out of the box found out the case was not machined enuf around the oil pump drive and the oil pump drive wire cut a new path on it’s own View attachment 170577the pump was destroyed I replaced it and the pickup line and the oil pump drive after re cutting the case to clear View attachment 170578now I have oil but it’s not enuf half tank of oil to one tank gas and the oil vale - cam all the way open or full oil so I’m wondering if my oil to thick it’s cold 32 degrees hear and the chain oil is malaises I’m going to try thinner oil and see any ideas ? View attachment 170579But the saw is running grate
1/2 cup of K1 to a 1/2 gal of summer mix oil. SHAKE THE F OUT OF IT.
Been buying tractor supply cheapazz paraffin based oil when on sale @ 5 bucks a gal.
