songoftheriver
New OPE Member
Hi, all. New to the forum, and first post. This is possibly related to http://opeforum.com/threads/newbie-looking-for-help-with-honda-gx240-that-wont-run.7996/ , but perhaps not.
Engine is attached to a pressure washer. It has been difficult to start for some time, but last weekend I got it running and used it for about 30 minutes. Then I shut it down (reduced throttle, shut off ignition) to move some things so I could continue washing. It wouldn’t start again.
I tried dribbling fuel into the intake, but it wouldn’t fire. I pulled the plug wire and verified that there was a spark, which seemed to max out at about a quarter inch or a little less in length. I tried various choke settings, etc, but it never seemed to try to fire.
I took the carburetor apart and completely cleaned it, including all the little holes on the main jet. Blew out with compressed air and cleaned with carb cleaner.
Same thing, no firing. Checked valve clearances, and they seem fine. Saw in the thread above that it should be difficult to turn the engine against compression, and it isn’t very difficult at all. I can feel resistance when the compression stroke is coming, but “should be difficult” is a little vague. I don’t have a compression tester, but maybe that’s the next step? My problem is that it was working, and compression doesn’t suddenly lower to the point where it won’t fire again.
Unless...Valve timing? Other thoughts?
Thank you!
Thank you!
