Homelite Super 1130G Is Here. Got??s
Beer Gut
A Fine Pilsner
12:41 AM
Northeastern Wisconsin
If my memory is correct, Homelite recommended sae 90 oil in the gearcase.
I use 75-90 synthetic in all my geardrives.
Don't use carb or brake cleaners as you can damage the decals and paint. I
wouldn't use any harsh detergents either like simple green, greased lighting,
purple power, etc as they will remove the decals and can hurt paint. I have a
safety kleen parts washer that works well and won't hurt paint or decals.
That's a very nice saw. It's a very late production one with the hand guard.
Have fun with it.
@Lone Wolf , @Lee H how full do you fill the gear case? It's pretty low was gonna empty and start with fresh. Do you guys know anyone with a owner's manual?
Beer Gut
A Fine Pilsner
12:41 AM
It seems to work good. I'll spray them down a few times and let it soak in. It's not the toughest grease breaker but it won't hurt the paint
Trying to do things better now days ask before going off. I always used raw gas. There are probably better ways
Lee H
10:41 PM
cape cod ma.
There is a brass plug on the side of the gear case that takes a flat screw driver.
You need to be very careful not to strip the spot where the screw driver goe's
so make sure you use the proper size screw driver. They can be tight. This is
the fill level with saw sitting in it's normal position.
Lone Wolf
1:41 AM
Nj
That's it yes good call.
Beer Gut
A Fine Pilsner
12:41 AM
I'l get pics tonight. The fill plug is labeled and at the top of the case. Then there is a spring loaded plug at the bottom but underneath the case, everything would run out.
backhoelover
I like tools
1:41 AM
lincolnton nc
View attachment 107293 View attachment 107294 View attachment 107295 View attachment 107296
This is overall pics. Had been sitting awhile, bought because I wanted one. All I knew was pics and it ran several years ago. I did only basic tests. Drop for comp I get tired before the bottom and give up. Clean as hell. Carb looks great on outside almost new, concern. But I will say auto, and manual oiler works great. Tank was DESERT bone dry put in some HP Ultra 50:1 maybe 6 pulls and running. Let her idle for 5 min, perfect. Boy these old girls pop and crack. Few blips seems perfect. More pics coming. And ?s
:babeando::babeando::babeando:
CJ Brown
I learned it from a hockey card...
1:41 AM
Belleville, Ontario, Canada
It looks like there may be a tiny plug right in front of the clutch protrusion on the gear case - right in front of the decal. The plug at the very bottom is your chain oil reservoir I think.
Beautiful old saw!
Beer Gut
A Fine Pilsner
12:41 AM
Beautiful old saw!
Yes both chain oil and gear oil fill are easy to find. Gear oil level screw is what I'm looking for. I'll look for the one you described.
Lee H
10:41 PM
cape cod ma.
It's right on the side just above the chain oil fill. It's a small 1/8 pipe thread plug.
I just looked at 4 1130's and i'm looking at a 3100G as i'm typing. Can't believe
you can't find it.
Beer Gut
A Fine Pilsner
12:41 AM
Beautiful old saw!
Found it. Top pic gear oil fill. Bottom pic, small pipe in font of decal is gear oil level, black cap at bottom b&c oil. You were correct. Thank You all. There will be more questions.
Beer Gut
A Fine Pilsner
12:41 AM
you can't find it.
Got it. Lol. Thank you
Lee H
10:41 PM
cape cod ma.
Take the plug out and full to bottom of hole. I would flush the oil
reservoir with some type of solvent to clean it out then fill with
the correct oil. I use 100LL av gas to clean mine as it cleans really
good and dries quick.
