Homelite, Poulan, McCulloch etc. Press Fit Wrist Bearing Pulling Made Simple Solution
Member
4:10 AM
Hey @Duke Thieroff was excited to use this tool again on a 10-10 piston right up until I saw it had a blind piston pin in it(no hole). Any words of wisdom before I head to the arbor press?
Duke Thieroff
Fill your hands you SOB!
5:10 AM
Beaver County, PA
@Stump Shot
Now that's one I'm gonna have to think about. I had never considered that even though some Macs and others used to be designed like that.
On first thought I think that job will be reserved for a press because of the way this particular tool works.
That's really a good call out, let me know what you end up with bud!
old 040
5:10 AM
Buckeye State
Mark! What's up buddy?
Yep, those are a great little tool as well and pretty similar to the Poulan style one.
Ever made any use of it?
Hey Duke...Yepper, go-to tool on certain equipment, by using small collars over the stepped down pin it can also remove/install bearings as well.
Member
4:10 AM
Perfect.
How do you like it?
I like it just fine most of the time. Of course chainsaws being so different there are times when it is not so easy. There is a similar tool made by Stihl that I think can be gotten from D.Dave at CCC's or there is a Chinese knock off that HLSUPPLY has for quite a bit less money.
