Homelite 770G resurrection
jeepsnchainsaws
4:12 PM
Central Missouri
Nice project. Best of luck with it.
I'm in the process of doing a 770GS stick shift
but I'm at a road block with a few missing pieces
And I started this project almost two years ago.
That stick shift is so neat! I hope to find one one day. What are you needing, I can keep an eye out.
Lee H
2:12 PM
cape cod ma.
I need the brake parts for the clutch drum. It's the second button you press to
stop the drum before you shift it. I haven't been hard looking for them just
kinda put it on the back burner. All parts painted, motor together, decals applied.
Also need a full wrap handle for it. Specific for the GS model as it is wider to clear
the chain case.
sawnami
5:12 PM
Springfield
This is the part where the design of this saw goes total hunchback!View attachment 56458View attachment 56460
That's what I thought at first but not so bad after I found the R&R procedure in a manual. Check the ball drive torque before you get it together. Let me know if you need any info Adam.
I've had several that someone pinched the broken end of the recoil spring in the split in the ball drive slipper to anchor it then found out that it would no longer turn the engine over.
Sent from my SM-T900 using Tapatalk
jeepsnchainsaws
4:12 PM
Central Missouri
The recoil consists of three balls that are supposed to engage the starter pawls, this is a very touchy design. Right now it will only engage if I shake the saw before I pull the rope.image.jpeg
Although I have the recoil cap which is usually the missing part on these saws, I don't have a cylinder shield yet. It will run without it, but helps it cool itself.image.jpeg
Lee H
2:12 PM
cape cod ma.
There should be a ball in every slot so if the motor stops in different positions
the starter will grab. The balls the cup and the drive part need to be clean and
dry or the balls will not fall and engage when you pull the rope.
jeepsnchainsaws
4:12 PM
Central Missouri
Yes sir! Check on all that. It sure is a pain!
rzonk
2:12 PM
madera ca
ever find parts? im looking for a brake for mine got a cylinder from a 77 (same bore size) slightly different shape fits great,also have some parts from 1936 that fit originally used that cylinder but smaller size (it did run) new reeds still avaible
