Hi. Welcome to the forum.
I have a few saws like that, and I’m happy to help with any questions.
If you’re looking for Oregon products, those saws take a bar that says A041 or K041 on it. That’s the model of bar tail you need.
Now, since you have a 3/8”LP drum on your saw, you need the A041 bar. K041 would only be correct if you had .325 chain and drum.
With that said, I’d look for a bar with the A041 tail and the biggest tip I could find. The stock bar has a tendency to easily throw the chain, due to a very small tip. That same small tip does help reduce kickback, though, so keep in mind that a bigger tip equals risk of more kickback.
This bar would fit your saw, and has the correct drive link count and pitch/gauge:
https://www.oregonproducts.com/en/single-rivet-guide-bar-16-in-a041-motor-mount,-ideal-for-woodcutters-using-small-electric-and-gasoline-chain-saws/p/160sdea041
Here’s another one that’ll fit your needs:
https://www.hlsproparts.com/product-p/13-16-801a1.htm
You can, if needed, convert a K095 mount to work on these saws quite easily. The A041 tail oils through the chain tension adjuster holes in the bar, where the K095 oils through a separate oil hole. To get a K095 to work on your saw you’d need to grind a channel from your bar groove down to the adjuster hole to open it up.
There are a few bars out there with the capability of doing both A041 and K095 saws stock for 3/8”LP, but they’re rather expensive, like Cannon.
Hopefully this was more helpful than confusing. Lol
