- 11:48 AM
- Aug 3, 2024
- Oregon
Please help my walnut sized brain under stand this!!!!
So how does a 24 inch and down chain fit both Husqvarna and stihl? but once you hit 28 you need 2 more links for the husky? If the same 20 inch chain can be used on a 20 inch Husqvarna bar and also be swapped over to a 20 inch stihl.. were da hell does the 2 extra links come in? Utilizing the same 28 inch stihl light bar on either of my "bigger" saws if it's on the 372 it needs more. I could understand if it was because of a different tip sprocket or maybe clutch drum sprocket but it's the same on both.
