ferris
- 1:47 AM
- Feb 12, 2016
- Germany
The big one is not only longer at the bottom. It is also a lot wider, that will help to clear the ships if ur noodling much.If you wanna spend your money on a nicer looking clutch cover, that's your call, but just so you know, the point of the taller cover is to keep you fingers and gloves out of the chain while using a wrap handlebar. There is no benefit with a regular handlebar.
