BigRed96
- 9:10 PM
- May 22, 2016
- New Richmond, Oh.
I call mine my lair.
Joe, I've got a couple of suggestions. Remember this is free advice and could be worth the same.
1) Metal bench tops, I used galv on mine, 16ga I think.
2) Build them as much as you can in length, you can never have enough
3) Gather up all the 2 liter coke crates you can. A broke down saw (waiting on parts) fits very neatly in one and I usually put all my screws and parts in a gallon zip lock freezer bag along with everything else to be put on a shelf back in a storage area. https://encrypted-tbn1.gstatic.com/...0EIGxtGJRWvLiu4P0xxmDQwZu17s5YGzcGst8_6_nlqKK
4) Buy you a bunch of those cheap Harbor Freight magnetic screw catcher pans, they go in the ZL bag also. http://www.harborfreight.com/4-inch-magnetic-parts-tray-90566.html
5) A buddy took a bunch of 2" angle iron and magnetized it and he uses that to separate projects, he does a lot of cylinder head work and it allows a defined area for each head.
6) When you want lighting give me a holler, I gots connections
7) Install a shop vac outside your shop and plumb it inside. Install a switch in your shop and it will pick up everything and be quite at the same time.
Some very good ideas,
Plan on using the 4ft 4 bulb fixtures, as I already have a few of em. Maybe invest in some good bulbs.
I have a fried that works for pepsi, may be able to get a hold of a few crates...
Do like the mag dish idea.
Thank you.
And those fixtures should be fine. Use these bulbs and throw the ballast away, they are LED bulbs that you wire line voltage to the tombstone. NO MORE BALLAST EVER!!!!!
http://forestlighting.com/t8-led-lamp/
I'm so done with 8' fluorescents. I'm going all LED soon. I've used 4 cases of fluorescent bulbs in 12 years. What a pain in my ass
At the time, I was price hunting. I bought (14) 8' fluorescent lights at about $30 each. I had good luck with them previously, but not anymore. I have to replace 8 or 10 bulbs a year, maybe more, idk. Out of 28 bulbs, right now about 12 work.LED's are definitely the way to go. T-8 fluorescents are junk. The t-5's I have had great luck with. Seem to last much longer too.
Move the air compressor outside. Build a small enclosure around it. Put a heater on the crankcase. Plug in the heater late fall, unplug early spring. My compressor has been outside for 25 years without an issue. 25 years of not having to listen to that godamn thing.
Maybe some Sort of an exhaust fan. I know we all like to fire up saws inside sometimes and I didn't see any windows in the picture Joe.
That's all I put in now. Spoils one real quick.T5 high bay lighting...really the way to go!! Can't wait until I get to build my garage, and make my saw space!! Looking forward to seeing updates.
They pick them up at Colemans.Have seen some neat tables at scrap yards and cl too. http://harrisburg.craigslist.org/bfs/5843840464.html
I agree, I will be making my next benches taller so I dont need to bend over.Tall enough and with enough overhand to sit on a stool.
