stihlproincky
- 8:04 AM
- Apr 30, 2024
- Kentucky
The solenoid is white.What color solenoid?
Did you rebuild the carb
Piston is a exact match.There are several versions. Did you compare the new with the old?
No, do you think I should?Carb rebuilt?
Given what you are saying, you may need to give the saw a little fuel mix down the throat then... i had to do that when i tebuilt my 661 m tronic, it had learned to the rapidly degrading piston and cylinder, and was so far off it wouldnt start... i use a little plqstic squeeze bottle to feed fuel into the carb until it learns (happens pretty quick on the mtronic 3.0 if you leave it in the triangle positionwhen starting) then proceed to do a reset, given a 2020 saw, would be triangle position, start, run for at leadt 30 sec in that position, peg the gas after 30 sec, it will rev up to about 10k rpm and sit on a limiter there, hold til it releases from the rev limiter and revs out to full rpm, then you can let off, and use the saw normally, you may have to do that several times during the ring seating process, i know i did on my 661.... Thats the 3.0 reset procedure...Buddy, you nailed it! this is a neighbors saw he he abuses it! Hella dull chain. Intake boot checked out, flywheel timing checked out, I ain't got a vac/pressure tester, but I looked over everything and it checked out. Thanks for the input
I finally saw some of the previous postsNo, do you think I should?
So here's what I heard, put a little mix gas in the throat on the carb, start on triangle once started let it run for 30 seconds on triangle, peg the gas ( hold it down?) Then rev it up to 10k rpm? Sorry I'm still learning.Given what you are saying, you may need to give the saw a little fuel mix down the throat then... i had to do that when i tebuilt my 661 m tronic, it had learned to the rapidly degrading piston and cylinder, and was so far off it wouldnt start... i use a little plqstic squeeze bottle to feed fuel into the carb until it learns (happens pretty quick on the mtronic 3.0 if you leave it in the triangle positionwhen starting) then proceed to do a reset, given a 2020 saw, would be triangle position, start, run for at leadt 30 sec in that position, peg the gas after 30 sec, it will rev up to about 10k rpm and sit on a limiter there, hold til it releases from the rev limiter and revs out to full rpm, then you can let off, and use the saw normally, you may have to do that several times during the ring seating process, i know i did on my 661.... Thats the 3.0 reset procedure...
Guess it helps diagnosing stuff like this being a certified stihl mechanic by day....LOL![]()
Thanks, I thought I had it wrong that's why I askedNo. Start it on triangle let idle for 30 sec. Pin throttle wide open. It will rev to 10, hold for a bit, then run up to full RPM without you doing anything besides contining to hold the trigger down.
Let it scream for a few seconds then it’s finished with it’s reset and ready to use.
Almost...everything is correct til your question, which is yes, hold the trigger full throttle after the 30 sec, the saw will act lije it is sitting on a rev limiter at about 10k, you will hear it vary a little bit, maybe 500 rpm one way or another, keep holding the throttle full til it revs up to full rpm, then it has learned the current conditions that the saw requires to run. Let go of the throttle and (not required but i like to do this with my saws) once back idling, shut it down and restartSo here's what I heard, put a little mix gas in the throat on the carb, start on triangle once started let it run for 30 seconds on triangle, peg the gas ( hold it down?) Then rev it up to 10k rpm? Sorry I'm still learning.
This is a v3 saw, so.... whats your point? Also we determined a super dull chain was the cause of the failure... this particular saw wont start and idle currently with a fresh topend... that needs a reset.... assuming that the cylinder doesnt have any air leaksThe LAST thing you should do is a factory reset on a saw that blew up for no known reason. You should get it to at least run first.
I’m not a fan of the V2 reset. Some suspect it’s caused the piston cracking problems in the version 1 462 (it has V2 MT). I used to reset every MT saw I did after porting regardless of version. I never do it anymore. In a few cuts, the saw will reset itself.
You better make sure you know why that saw failed the first time, otherwise you will just toast it again.
And my '17 661 is also v3.... so.... yeah.... i know Doc is well respected but.... hmmm
My point is that the new style reset requires a prolonged high rpm unloaded period. If you have an inherent problem that roasted the piston, you would want the saw at least running before the reset.This is a v3 saw, so.... whats your point? Also we determined a super dull chain was the cause of the failure... this particular saw wont start and idle currently with a fresh topend... that needs a reset.... assuming that the cylinder doesnt have any air leaks
