Hand Making Axe Handles
ajschainsaws
Axes never run out of Gas
9:03 PM
South west UK
If it is anything like flooring, it is very very dense material. Usually has some sort of epoxy type straightening material mixed in on stacked end grains. Hard stuff.
I tried putting a burn on it to see what it would look like and it went a yellow white immediately so defiantely epoxy In there
ajschainsaws
9:03 PM
South west UK
Here you go Wilheim.
Always like seeing this axe of wilhelms superb beast fit for any Viking
Thanks for posting @RI Chevy
ajschainsaws
9:03 PM
South west UK
I smack a steel wedge in till the handle starts "singing", drill a hole through the wedge and secure it with a nail that I peen over on the exit side.
I drilled the ax head to have holes going through both sides and made a small countersink for the nails head and the peened side.
Works pretty well, no more loosing the wedge at the most inconvenient moment.
It seems to be a rather local design.
Try searching images on Google for "bosanska sjekira" , mine is very close to that design.
It seems that these can almost exclusively be had from blacksmiths.
Mine is closest to image number 2, Bosanska
The wide eye is somewhat of an issue when one needs to replace the handle as the handles sold in shops have a much narrower eye end.
I got mine in my teenage years, over two decades ago.
Some fantastic styles on that paper I bet I wouldn’t be the only one who would like the brother to your axe
ajschainsaws
9:03 PM
South west UK
10:03 PM
Ive heard of this cherry from different people but I read up about it tonight and didn’t realise it was I; t(e dogwood family and it’s dense as hell perfect for(andles
Around here people are so short sighted they crawl into the bushes, look for a old larger sized Cornelian Cherry brush and cut out only the stem to use it for maul and bat handles.
I have a property that borders on a Cornelian Cherry brush lot.
Multiple times per year some of my neighbors cut out the main stem of the largest and healthiest specimen - that kinda annoys me.
When I do bush clearances I cut down everything but the Cornelian Cherry.
As said before, I would love a Cornelian Cherry ax handle, but it is hard to find a piece that has the desired dimensions and straightness.
Cornelian Cherry tends to grow twisted within itself and nearby specimen.
10:03 PM
Has been reseated since.
Same old handle but new steel wedge driven in to max depth to secure the head.
Has seen a lot more work too, might need a sharpening soon.
New pictures
ajschainsaws
9:03 PM
South west UK
10:03 PM
I might have cut a straight piece of maple today for testing purposes. I may try to split a section out of it for a handle. Just not sure about splitting it now and leaving outside. Bring it inside. Not sure about warping more than anything
Leave it longer than You intend to make the handle and let it dry at least partially un-split.
That's what I would do.
XP_Slinger
They’re Just Saws
4:03 PM
Central NY
Not a fix-all for cracking, but if you mix equal parts of hot water and regular Elmer’s glue then smear a thick coating on the end grain it does help hold it together. I haven’t had any problem with warping because flat sawn or split billets “cup” when they warp. Very easy to reshape the billet for a nice straight handle. Illustrated in this diagram
XP_Slinger
They’re Just Saws
4:03 PM
Central NY
Have you considered, or tried, laminating some thinner boards to make a handle?
Philbert
I’ve thought about it but don’t know jack about laminating wood and having it be strong. Could definitely create some great looking handles with dark and light layers.
