mx8sst
OPE Member
- 2:59 AM
- Jul 23, 2021
- Wales in the United Kingdom
Hello all.
Can't see any cylinder numbers/letters yet as I need to blow all the sawdust out from around the base of the cylinder flange but, I can see "made in Italy" on the flywheel side of the cylinder bolting flange, and the 4 square corners of the bolting flange have radii corners machined on half the thickness of the bolting flange. (a common style/type of machining on other models of Gilardoni chainsaw cylinders)
Would it be a Gilardoni cylinder, it has a "B" stamped near the spark plug and 2 small digits of either a t & ? or + & ? on the clutch side just above the square base flange of the cylinder.
Chainsaw date and model is a 1997 42 special s/n 7350580.
Thanks all
Phil
Thanks all
Phil
