Adamski
Plebus Splederns
- 2:57 AM
- May 3, 2017
- Essex, UK
I disagree. First of all it’s really hard to qualify something as for farm use vs commercial use, except for a marketing department to convince you to open up your wallet for higher costs.
Secondly, the Dolmar 421/Makita EA4300 has mag cases (not clamshell), and is very close to other ~40cc saws in power/weight. It is only .3kg (8oz) heavier and makes 0.2HP less than the Husqvarna 242XP. If you remove the cat in the muffler you likely have your 0.2HP back, and gain better AV, better parts support, a side chain adjuster, and strato tech for cleaner emissions and better fuel economy.
Compared to the Stihl 241Cm it makes 0.3HP less with only 0.4kg more weight, BUT it costs less than ~1/2 the price. It is a little wider and fatter than the Stihl, but if you’re not taking it up into a tree, it could make a lot of sense for you.
This.. is... all.. correct. [emoji106]
How anyone can call a 421/420/4300 a consumer/farm saw is beyond me. Exactly the same pro construction and a damn sight more durable if you ask me.
