Generac Standby Unit and Preventive Maintenance
hotajax
1:10 PM
Eastern PA
I need to change oil, and clean battery terminals. Is there a way to take just the generator off line, and NOT take down house power with it?
Thank you.
Woodtroll
1:10 PM
Mtns of SW VA
On the newer ones (last 6-8 years or so at least), yes there is. You just push the "Off" button on the control console. I've installed and maintained two of these, one a 17 and one a 22?(I think), at my son's and parents' homes, within the last few years. Both have whole-house 200 amp automatic transfer switches. You'll then have to push "Manual" to get it to start and run to check the oil level after service, and then make sure you put it back in "Auto" when you're done. Your generator may be older, or a different setup, but you should still be able to take it offline for service.
av8or3
1:10 PM
Waleska,Ga.
What he said^^^^^. There’s probably a small rocker switch on the outside that’s used as an emergency STOP switch, one just like it inside. Either one of them go open the generator won’t start. Just remember to set it back before you run it manually to check for leaks. You should know you don’t have to switch power to check for leaks either.
hotajax
1:10 PM
Eastern PA
Woodtroll: Thanks a lot. Appreciate your comments. HA
