Lightning Performance
- 3:30 AM
- Jan 26, 2016
- East of Philly
518Not using gasket
518Not using gasket
Spread it ,that way you know it's where its supposed to be and doesn't just make a messLast question, I think, is it better to leave the motoseal in a “string” or knocked down to cover mating surfaces?
Thanks, How do you “break the shinny face down some”?Very low radial tension on the rings. That goes away at operating speeds.
Poor ring seating or glazed cylinder walls with new rings installed with out breaking the shiny face down some.
Leaking decomp during testing.
Bad test gauge or Schrader valve.
I like red scotchbriteThanks, How do you “break the shinny face down some”?
That pretty much sums it up.lol or egg shaped cylinder or piston.Very low radial tension on the rings. That goes away at operating speeds.
1500 to 2000 isn't shinny... yet.I’m a little confused here. Are you talkin bout breaking down the jug or the new rings. If jug I really worked it over with 320 emery cloth, nice and shinny. Ok, I’m almost understanding. Thing is, other than last question that’s how I been doin it. Thanks to all for all the help and verifications
