Gas trimmer Shaft Adaptor ? square to spline
BiOs2k
New OPE Member
10:00 AM
Canada
Hello everyone, I'm new here and new to Gas trimmer.
I bought an Troy-Bilt 4 cycle trimmer and I discover the ability to change attachment head.
I know it's not a Stihl trimmer but I think it will serve me well..
Ok my question is; the Shaft on my trimmer is square, and I see alot of very cheap addon on Amazon and Ebay with 7 spline shaft.
is there an adaptor or a way to have my square shaft fit into a 7 spline trimmer attachment ?
Thank you
e.fisher26
10:00 AM
Ma, USA
I didn’t even know there were splined shafts, I do know the tubes are different sizes on the stihl’s.
9:00 AM
Thank you
I've only seen the square shaft attachments. Got a like to this 7 spline stuff?
Steve
Excellence!
9:00 AM
Thank you
Ive never seen splined shafts either. Only square.
And who the hell wants a stihl trimmer? Everyone knows If you wat a real trimmer you get an Echo!
And welcome to the club! :beer-toast1:
BiOs2k
New OPE Member
10:00 AM
Canada
Here is a document I found about shaft connection and different size. very interesting..!!
https://www.turfmaster.co.za/brushcutter-gearbox.pdf
Echo!... yes I've see some used trimmer during my search. what is the advantage on ECHO compare to other brand ?
I know that my troy-bilt is a no name china motor and the reviews on TB590EC is not good. but i'm good in mechanics and for me this trimmer start on 3-4 pull!. And I must admit that I love the fact that is a 4cyles motor but it's heavier then a 2stroke engine.
I can confirm like every youtube video that a 4stroke trimmer is much harder to control low rpm/cutting ability then a 2 stroke.
Steve
Excellence!
9:00 AM
Echo builds a high quality very reliable unit for a good price. Down fall is they are over built and heavy relative to other trimmers.
Steve
Excellence!
9:00 AM
Is your trimmer the one that has a quick link in the center or did you just remove the gearbox on the end?
9:00 AM
My Troybilt is the quick like in the center and I use a hedge trimmer attachment from Walmart and a Ryobi straight shaft attachment with no problems since their all made by MTD. Hell I even took a shaft off a dead TB and made it fit on a Stihl FS 75 power head with minor work. All had the square lug that I could see.
