gas cap HELP!!!!!!!!!!!!!!!!!!!!!!!!!
mirage
10:48 PM
idaho
this cap is frozen to the tank. Have put all kinds of penetrating oil on it no luck. Can anyone give me some info on how to get it loose. Don't want to put pliers on it . ThanksC263D4D3-7144-45DE-869B-40117B51ED3E.jpeg
mirage
10:48 PM
idaho
Thanks. I was thinking about the heat gun but not the strap wrench
DuratecMan10
12:48 AM
Florida
Wrap the jaws on the biggest pair of Channellocks you have in electrical tape, heat it up and go.
blacksmith
12:48 AM
central PA
If you don't have a strap wrench then I would use a strap of leather to protect the cap then put the channel locks on that. The leather will provide some much needed grip. Just make sure the leather is a little more on the rough side so it will grip a little better.
Bilge Rat
12:48 AM
savannah georgia
Soft jawed pliers that gunsmiths use. Jaws are curved on these.
They are used to remove magazine tubes on shotguns and such.
11:48 PM
Have you tried 50/50 ATF and acetone?
mirage
10:48 PM
idaho
Real good friend of mine worked for Briggs and Stratton. In the Snapper part of it.
TALLGUY
11:48 PM
VERMILLION SD
I had that issue on my Reed Prentice. Grabbed it with soft jaws smoking hot. Snapped the top right off. Threaded part still stuck in the hole. Ended up cutting it in 3. Little JB weld and its as good as new.
DuratecMan10
12:48 AM
Florida
That's awesome. I'm a huge fan, owned, used and worked on many of their engines over the years. Always the easiest to get started and held compression. [emoji41]
MG porting
9:48 PM
Wa
You got all the answers you need.:beer-toast1:
mirage
10:48 PM
idaho
Anyone got a gas cap that will fit this saw ?
12:48 AM
I had to break a cap on the tank of a Mac 125 .Took me forever to find another one .I used a wire brush on a Dremel to the tank threads and Kopr- Kote them .
