ElevatorGuy
It’s up and down ;)
- 12:34 AM
- Jan 5, 2021
- Maryland
They win for sure.Funnest way?
Probably a pretty safe way to do them. You could get way the hell outa the way.Grandpa used to fell big trees that way when chainsaws were in the embryonic stage. He was a dynamite wholesaler. The ground would shake. Most of the time, however, he used the dynamite to blow rocks buried in the ground apart or skyward.
Even more funner if you do a few and fuse them together...Funnest way?
The music in the background made it even betterFunnest way?
I wish I had come back and refreshed on your destructions before I went out. Started out with full comp 28”, wasn’t biting and got dull. Didn’t want to sharpen all those cutters in the field so I switched to skip I got from @Benwa up in softwood land. Dummy head me, it was pretty grabby noodling dry oak...Always saving this work for saw break-in runs or tuning.
The 90cc or bigger saw always gets the nod.
A seven pin rim and off the reel chain or something set up for hardwood. Softwood chains put a lot of stress on the clutch and stuffs imo. Most times the spike drags so having a slide vs a spike helps. Turn up your oil pump to max. Running a 41 or 42" bar doubles your cut. Blocks between them clears the cut better. My built milling saws finish the big nasty chunks laying around with a 36" when not testing. Large Y's get the same treatment. I'm not spitting those.
Screw up one depth gauge and you will need to go find that cutter and shorten it. That's all I got.
PossiblyI wish I had come back and refreshed on your destructions before I went out. Started out with full comp 28”, wasn’t biting and got dull. Didn’t want to sharpen all those cutters in the field so I switched to skip I got from @Benwa up in softwood land. Dummy head me, it was pretty grabby noodling dry oak...
What seemed to work at least to start was dropping in bar tip down almost 45*. Sometimes it would just slam to a stop like I’d hit the brake or a big spike in the wood. Pull it out and the cut would be full of noodles but not the clutch cover or choked between the bar n chain. I think it was what you’re saying about rakers too far down. Difficult to modulate pressure to keep it cutting but not grab.
I also think there might be something funky with these tsu bars...had similar funkiness with the 24” noodling on the 2159 once.
I may go back with the 395 and a new 24@ chain on a good std bar and educate mineself....or confirm what I already been told!
No more work.That is bad ass.
