Fuel starvation at idle?
merc_man
merc_man
12:14 PM
southern ontario
You have a pressur / vac tester. Id double check for an air leak.
WoodShed
12:14 PM
Southern Ohio
Hmm,
Ive had 5 or so 590's some of them fought me, but nothing like that.
Can't say for certain. Possible air leak.? Check the impulse hose for nicks/holes.
What did you use to seal the jug?
I Don't touch the idle screw, maybe just set it a bit high until I get the low close. Fix the idle then check the H tune.
Saw didn't do that before your mods?
I used Ducati bond which is Three Bond 1207B. Also cleaned the cases and jug well with brake clean.
I checked the hoses, but could be something I can't see.
WoodShed
12:14 PM
Southern Ohio
Unfortunately I do not have a vac/pressure tester. Would a shop/dealer be able to check?
Is the impulse line on top of the carb?
I didn't have the problem before.
Red97
12:14 PM
MI
Dealer may do it for ya, but likely cost the same as buying a mityvac and an innertube/gorilla tape.
Yes impulse is on top the the carb, other side is in the case below the intake boot.
WoodShed
12:14 PM
Southern Ohio
Ha. Actually I think I do have one of those somewhere! I guess I was thinking about a leakdown tester.
I'll have to do some research on how to mock it up. I guess plug the intake and exhaust is a start.
So is the impulse line a static air source?
tree monkey
11:14 AM
wi
change the pump diaphragm , if that's not it then it's the acc pump
jmssaws
Banneded
11:14 AM
I had a wj6a on a 064 today that ran perfect but after 10 second idle it would start to lean surge and die regardless of carb setting.
It was the fuel pump.
JimmyD
New OPE Member
5:14 PM
UK
I'll change the pump diaphragm when the kit comes in on Wednesday.
Can the acc pump be replaced, or is that a carb replacement?
Hi woodshed, did you ever solve this issue? I have exactly the same problem with my saw. I've replaced the pump diaphragm (albeit aftermarket) and it does not seem to have made a difference. Saw runs fine otherwise, just starts idling high when left for a few seconds after cutting. Cheers
JimmyD
New OPE Member
5:14 PM
UK
In case this helps anyone else, I believe I have solved the issue (at least in my case). The saw is an Echo 620sx. The metering lever was set too low, which results in a lean condition which is most obvious at idle. I adjusted it according to the Walbro HDA manual. I've not tuned the saw in wood since adjusting the metering lever, but I left it idling for approx 1 minute and it did so perfectly, whereas previously the idle would have raced after about 5-10 seconds.
I did also notice the high needle needed to be screwed out quite far to get good performance, so hopefully this too will be resolved when I get round to tuning it properly again. I bought the saw used with this issue.
