Funky sawman
Pony Power
- 10:18 PM
- Feb 10, 2017
- North idaho
Allready did tree monkey mod
Definitely not the throttle control rod, I completely removed it and doesn't helpThrottle cable sticking, butterfly not aligned or bent shaft. Those are things to check.
It doesn't bind until half throttle or moreTry turning in the idle stop screw a 1/4 turn or so, and see if it still binds.
Holy crap! I just realized its you Scott! How you doing you ole fart?I don’t see how the acc pump can cause it to stick wide open. You Likely have a bent shaft
