Jags
Active OPE Member
Was having problems with idle after warmup. The saw is 24 yes old but not used alot of hours. Purchased vac/pressure pump. Blocked intake at carb flange and exhaust. Tested. Could see the needle move and drop. Then replaced crank seals. Now I can't get anything on the pump. Is there any reason you can't go through the pulse line where the carb connects? Thanks for any help
