Fruecrue 660 build thread
Fruecrue
certified hand catcher
10:17 AM
Alden NY
Huh?
I'd expect more advance to speed it up.
Before the advance, I couldn't slow it down
while tuning but it didn't hold rpm in the wood.
I was 3 turns out on the H, running a wj67 with .74 jet, seeing 14,400 - 14,700 after a terrible bog.
Fruecrue
10:17 AM
Alden NY
Checked this morning, lost 30# compression.
Lower ring has a bevel where it was passing a transfer port. Cylinder has light vertical striping 360 degrees.
Pics soon.
Fruecrue
10:17 AM
Alden NY
Also small marks in squish band, most likely small pieces of plating missing from cylinder walls.
Fruecrue
10:17 AM
Alden NY
Wondering if same thing happened originally, but caber ring cracked instead of wearing away like the hyway ring.
10:17 AM
Seen a Mako cylinder the plating was bubbling on. Saw wouldn't tune for long. Pulled it down and there was a spot the plating was a small bubble. If it had burst it probably would have done some damage but the rings didn't cross it.
