Frogzskin vents for air filter covers
6:31 AM
It might fit but I doubt it.
redoakneck
6:31 AM
Ohio326
Anyone compare a max flow to a uni filter , probably very similar??
Redbull661
661 hoarder (BlueBallz)
5:31 AM
MN
I ran a small oil test today between dumonde dtp and honda hp2. First I ran dumonde. Then when I switched over to honda I ran the saw for almost a tank just cutting to let the mtronic get used to honda hp2 in th
big t double
You can call me Teddy Eastwood.....
5:31 AM
I think the next logical step would be to install the frog skin air filter cover back on the saw, then light the whole saw on fire...using the accelerant of your choice of course...then examine the air filter. I think that would really test the integrity of the frog skins. Thoughts? Go.
Toad22t
5:31 AM
Central Wisconsin
Hoping they provide
1. more air flow
2. more cool air
3. more air flow/circulation. Hoping that keeps the chips from building up in the grooves of the air filter.
thinking about the covers...
Guess I am theorizing that while the first cut might be fast. The next cuts may slow down because of…
1. Air temp rising inside the air filter cover
2. Because of not enough air flow because cover isn’t open enough ie. the vents will help
3. Because of chip build up because not enough air flow circulation ie. the vents will help
well that is the next step. See how they hold up to normal use.
It's always BEER:30 some where in the world! :beer-toast1:
mango - first time trying it. Pretty good!
they sent me this pdf to print out and cut out. See how these would fit for your saws. I'd like to come up with a few sizes that would be universal for pretty much every one here.
He's from Wisconsin, it's always beer thirty! A wise man once said, "you can't drink all day, if you don't start in the morning!"
I like the long thin one.
I'm not here to judge!
Send the saws that you want tested to me and I'll put them to the test. If I don't come back with video's or data about these test's. Just keep waiting. Lol!
Stihl working Hard
Is it Friday yet
6:31 PM
Perth Australia
I'm going to try a few saws on the Dyno tomorrow with and without covers. Ported and stock. See if this is really going to make a difference.
Did you find any significant gains on the dyno @paragonbuilder
paragonbuilder
6:31 AM
Norwich, CT
sawmikaze
6:31 AM
steeltown
I have a date tonight with a big girl and was wondering where i could buy some frogskinz.
big t double
5:31 AM
Were you planning on lighting her on fire? Frog skins protect against fire...at least that's what I've gathered here so far. Plus...pics of your date.
Scott0154
Feral member
3:31 AM
Central Valley Ca
I ran a small oil test today between dumonde dtp and honda hp2. First I ran dumonde. Then when I switched over to honda I ran the saw for almost a tank just cutting to let the mtronic get used to honda hp2 in the system.
Point: this is what the filter etc looks like after running it for almost a tank.
Any difference in how it runs? I like how it looks
sawmikaze
6:31 AM
steeltown
Jules you are one innovative sumbitch..i like this frogskinz idea..seems like a good addition to stihls 17th century air filtration..im gonna try it.
6:31 AM
They breath better than one would expect. I added some to my 360 today
Nitehawk55
6:31 AM
Ontario
These don't excite me too much , I really don't see the need nor do I want to mess up my plastic.......sorry , someone had to say it .
6:31 AM
Some of us don't care about looks and want performance. I don't own oem air filter covers for most of my stihls. I don't run them.
