countryhog
BTDT
- 3:04 PM
- Jan 19, 2016
- NW Arkansas
One if the frankinolys i built resists tuning. Replaced seals. Still resists.
On the premise that its sucking air i took the jug off. So its either the gasketless joint between jug and case or its a leak between the carb header block and the jug.
When rebuilt i deleted gasket. Done that on several other saws with no problems. I saw what could have been a break in the yamabond; not sure but could be. So i either try gasketless again or make a gasket from coke can. If i use coke can gasket do i need to use yamabond or can i do it dry?
Inspected the header block, couldnt see any cracks but an edge had chipped. When compared to the carb gasket it may have been leaking there. Went ahead and made new larger gasket that should cover it. Btw, have another header block but can see hairlinecrack from outside to the inside; would that cause lean condition if i used it?
Dont have pressure/vacuum tester which is why i havent tested it. Would have been a lot easier and more exact but i gotta use what i got or dont use what i dont got.
Other than this issue and wear marks this is a solid saw. Thanks for any thoughts and recommendations
