Ford CL20 skidsteer lift cylinder removal
Wet cat carl
4:24 PM
East Jordan
Any chance someone here knows about these old machines? I recently got a deal on a late 70s Ford CL20 skid steer. I'm starting to tinker with the issues I've found. Its leaking hydraulic fluid from the lift cylinder seal as well as the bucket cylinder. Both are on the right side of the machine. I've got the bucket cylinder removed but I cant get the pins out for the lift cylinder. Am I doing something wrong?
4:24 PM
get some pictures carl and it may help
Wet cat carl
4:24 PM
East Jordan
Here's pictures
4:24 PM
if you move the cylinder sideways in the hole does the pin move with it
you may need to heat and beat
heat up where the pin goes through the cylinder and beat the pins through
