redline4
I'm huge in Japan
- 5:21 PM
- Mar 12, 2018
- Rosholt Wisconsin
This saw was assembled from a box of parts I got from @dall last summer.
Assembly went great, carb got an aftermarket kit at the time and ran great.
Last real use was up at @Stump Shot and it saw 2 or 3 refuels that day.
Used it a few times over the winter with no issue.
Took it to work one day to clean it up after use.
Noticed fuel pouring out carb while sitting on bench.
Swapped tank vent. Still did it.
Swapped different, non rebuilt carb, still did it.
Noticed if I opened filler cap, would quit.
Put saw out in my truck, it quit. Assumed it was the radiant heat at work causing the tank to build pressure.
3 weeks later, pulled off air filter, carb was dry. 5 minutes later and gas was pouring out of it.
Ordered walbro carb kit. Got sent a K10-HDC kit.
Reordered kit. Got a Chinese kit.
*f-word it, installed it.
Held 7 psi. Popped at 20 psi and bubbled until 5 psi..
Put carb on, runs ok
Set saw down and less than 1 minute later, started to fill crankcase again.
Crappy vid..
So, what is my dumbazz missing or doing wrong?
It's had 2 different carbs, 3 tank vents.
I noticed the o-ring on the flippy cap started to leak too.
Crappy vid..
