Cerberus
Cerberus the aardvark, not the hell-hound!!
- 11:07 PM
- Jan 20, 2020
- Florida (tampa area)
My new 590, barely 2-3 tanks through it (~40:1 using HP Ultra and Stabil in eth free 92 oct, fresh fuel) Even after muff mod & airbox mods, the carb didn't need adjustment for Idle or Low (hadn't set H yet, wanted to get my baseline compression benchmark, then was gonna go set H while spending half an hour getting a better feel for the unit)
Problem is I'd never checked engine-compression, I went and got a $30 comp gauge from the auto-store (which I was told was OK), I insert it to the spark-plug-hole only to find it goes in too-deep & blocks the piston...I back it out 1/2 or full turn, and now it works, each time I pull the starter the pressure builds, seemed real nice&linear, until ~91psi where it just stopped!
Would be very eager to hear you guys' thoughts on this....I was in love w/ this saw, and had/have my most ambitious saw-mod plan for it yet, but if "it's a lemon" then I'd sooner sell it and buy another (and just get the 620p, now that I know I can buy powerheads-only from one of the good saw-sites!)
This was a floor model, so people surely pulled that cord while the engine was dry IE no oily-fuel but when I did the MM I, naturally, was checking out the P&C and (at least on the exhaust side), they looked flawless...
Can't tell if my reading is sure to be off (and if so, whether it's the unit or the operator/myself), or if my new 590 is problematic :/ Would greatly appreciate any&all insight on this one!!
Thanks a ton!!
PS-- benchmarking...I don't have good "video + stopwatch" setup, and - to me - the best benchmark is cutting-speed, so to that end my plan for benchmarking - which I intend to do a ton of while modding this saw - is to simply film myself doing 2 or 3 cuts then using a stopwatch when watching the video....my thinking is that since it's 3 cuts, it should help give better #'s (IE account for variance-per-cut, and for inaccuracies of my timings) Just took home a log yesterday that's a good 1' wide, nearly 8' long nice and homogeneous, will be the 590's benchmarking-log!
Thanks a ton!!
