Turd Furgeson
Hey Guys,
COVID isolation has my CAD flaring up more than it has at any time since I bought my first saw 12 years ago. I have quite the collection of muscle saws now, and I'd like to avoid having to tear every one down to the bare bones to clean it up. Most of these saws pre-date the modern mixes and clean burning oils, so for the most part when I pull the mufflers I find a ton of carbon buildup in the exhaust port and ring grooves. A 795 MAC I picked up was almost 100% blocked in a couple of the ports. Luckily most saws still have great compression, but I want to get rid of that carbon before it causes issues.
So, while doing research I ran across Stihl Decarbonizer which has since been discontinued. From the people that have used it they love it. From what I read, some dealers refused to stock it because it would mean less service work and sales of new equipment.
Right now I'm getting carbon out with screwdrivers and picks, but that comes with it's own risks when you get close to the piston, and if some broken up carbon finds its way into the engine. A chemical solution that does most of the work for me would be ideal.
You can buy EDTA solution or powder to make your own solution on Amazon. Does anybody have any knowledge of EDTA? Are there any risks using it? I'm sure you need to be careful and make sure you have sufficient lube in the cylinder after decarbonizing before firing it up. But that should be simple to do. Does it react with the aluminum or plating at all?
Do you guys have any other tricks for getting rid of carbon?
Thanks!
Scott
Thanks!
Scott
