Echo cs670
motoOzarks
motoMonster
8:27 PM
southwest Missouri Ozarks
Yeah, I shouldn't have, but I did
A cs670 came up for sale near by and I bought it.
Starts easily, idles well, runs.
Dirty but not beat up from what I can see. I have not put it to the wood or got it all hot n bothered yet.
Pulled 145# compression, I don't know what it's supposed to be.
Came with a dinky 18 inch bar. 3/8 .050
I would like to hand me down my original Stihl 044 20 inch bar and put a new 24 inch on the 044.
The bar mounts are not the same. Studs are skinnier. I've seen bar adapters mentioned and have started to look but I'm not knowledgeable about them.
I left the saw at the farm and of course did not measure the studs as I thought I could find info easily but there are so many options I'm confuserated.
What is the bar mount size on the 670? What adapter(s) would work?
Is changing the studs to Stihl size possible? Preferred?
What would you do?
motoOzarks
motoMonster
8:27 PM
Grind down some hex nuts as a spacer collar? Cut a hunk out of a tube?
Apparently the bar studs are not screw in mount. Rather are square headed and mounted thru the oil tank.
Sugihara multimount bar
stretch5881
8:27 PM
Hatley, Wisconsin
From what I can find, the Echo bar mount pattern is D176. If you do a google search for chainsaw bar mount adapters, you will find what you need. Try to keep it simple with the least amount of parts. If you have to remove the bar in the sticks, less parts to drop.
motoOzarks
motoMonster
8:27 PM
I agree
I'm even willing to just get a new bar for the 670.
D076 must be similar
The bar nuts use 13mm wrench and I think(forgot to measure) means 8mm stud. All the adapters go to 9mm. which is still a little loose and I don't want to pay for that.
motoOzarks
motoMonster
8:27 PM
240388101 guide bar 24DOPS3881 echo part number for guide bar
727081 72V-81G echo part number chain
PowerCut™ Guide Bar, 24"
Part# 240RNDD176
81 link
Home Depot
  • 24 in. laminated bar with 0.050 in. gauge and 0.375 in. pitch
  • Mount application: D076/D176
  • Compatible with current ECHO chainsaw models: CS-590/CS-620P/CS-620PW/CS-680/ CS-800P Older Models: Older Models: CS-600P/CS-670/CS-8000
  • Compatible with ECHO chain #: 72LPX81CQ
$87.50
ECHO's 24 in. replacement chain (72LPX81CQ)
$31.76 Full chisel
$119.26 total
84 dl
Oregon Power Match Bar .050" x 3/8" Gauge x 24" Pitch 240RNDD025
for 044
Oregon 72EXL084G PowerCut Saw Chain 24"
Lightning Performance
9:27 PM
East of Philly
Good point above made by your Elwood City fan :)
These Echo bars are a pia if you don't have a local Echo dealer with odd dl counts on loops and bar lengths.
I run a 72 or 84 dl on this saw.
Oregon makes three Uni-mount bars that drop right on these saws or buy a new lw one as suggested.
I run Stihl bars on my Makita saws without an adapter. You just need to line it up right. A steel band wrapped around both studs shaped pike a paper clip works just fine and you won't loose it. One guy on Ebay did sell the machined aluminum adapters to bolt on your saw to run Stihl mount in D025. Old Mac fits this mount if you can find one in regular 375 dl. Mac also had their own chain type so be careful there.
I did not watch the videos you posted here.
Wood Doctor
Edwin
8:27 PM
Omaha, Nebraska
I have also made these adapters (shown in #9) using two layers of plexiglas held together with double-sided tape. That provides the thickness you need and works also. The steel band idea also works, but you need to find the right width band or grind one down.
I cannot believe some guy used a dinky 18" bar with this saw. It will even pull a 32" bar and chain through red elm. My "standard' for it is a 25" bar, but it largely depends on what I am cutting.
9:27 PM
East of Philly
I cannot believe some guy used an 18" bar with this saw. It will even pull a 32" bar and chain through red elm. My "standard' for it is a 25" bar, but it largely depends on what I am cutting.
I run a 20 375 bar and that is what's on it this day. Got you some pics.
The factory Echo 20 325 is shaped like a Cannon bar. Maybe this will help some.
K041 needs an oil hole drilled in it. I believe that is a Jred mount... not completely sure about that. Could be a Husky/Dolkita. Makita OEM mount has a different tail.
9:27 PM
East of Philly
Posting pics here today is about impossible full size. The server refuses to cooperate
GL with those pics
9:27 PM
East of Philly
I run those chains and short bars for bore cutting stumps to see if the tree is hollow or not. They go pretty good in dirt. This thing has the oe stock grunt and large oil pump with the acc oil pump to power right in there and dig around before felling happens on sketchy chit.
Wood Doctor
Edwin
8:27 PM
Omaha, Nebraska
GL with those pics
You can shrink those Pics by loading them into Adobe. Remove the white margins, and then save as a JPG. A 3 MB Pic suddenly is shrunk by a factor of 10 or more. The Pic file posted in #9 takes up only 140 KB, believe it or not. Each Pic by itself was over 2 MB.
pavel408
3:27 AM
EU
K041 is typically used for Echo/Shindaiwa 30-50 cc and Dolmar/Makita 30-40 cc saws.
